Apple Car Play
18.06.20, 22:14:37
Zitat Captain340
Da hat sich Honda nicht mit Ruhm bekleckert. Der ganze Elektronik-Kram inclusive. Navi ist einfach nicht gelungen. Das muss man akzeptieren.
Tue ich mein Lieber!
Dafür habe ich Druck und Macht ohne Ende, ein wirklich beeindruckendes Motorgeräusch, die entspannteste Sitzhaltung ever und das Gefühl King of the Road zu sein,
da kann Mann auch schon mal zurückstecken.
23.06.20, 18:33:32
MyRouteApp will be available for AppleCarPlay in the near future. I’ve mounted a Garmin XT but I will sell the Garmin when MyRouteApp is available for Carplay.
Attention community,
By your request we've chased down the opportunity to develop products for next-generation vehicles outfitted with Apple Carplay. On behalf of the team I'm very happy to announce that MyRoute-app has finally been granted access to Apple Carplay development. This means that we will be able to make our apps available on Apple Carplay in the future.
We've been petitioning both Google and Apple to grant us access to their respective systems since 2018. Every single time we've been ignored. At the same time, many members in this community who use Carplay kept asking us when they could expect Navigation to become available for those systems. As a final act of defiance we reached out to the European Commission's Anti-Trust Agency. After gathering knowledge about our rights, we made a final plea to both Google and Apple to grant us access.
Slightly later than requested, we gained word from Apple that they had failed to pick up our previous requests. They immediately granted us access to the Apple Development area (for which we are very grateful). We look forward to working with apple to bringing MyRoute-app to Carplay compatible devices. Since we are now finally in contact with Apple and have received an explanation for the events as well as a workable solution, we will not pursue an Anti-Trust investigation. Sadly, since Google hasn't reacted, we will have to come up with a different strategy.
In light of continued full transperency, see the attached communications between Apple and MyRoute-app below. We've omitted all private and project information for reasons of privacy and partnership.
MRA community manager
23.06.20, 21:27:20
Ich frag mich gerade ob der Beitrag von jelle (MRA community manager) nicht in die Händlermeile gehört.
MyRouteApp ist ein kommerzielles Produkt, bei dem man im jährlichen Abo eine Menge Geld lassen muss.
Gruß Jörg
23.06.20, 21:45:40
Was ich noch befremdlicher finde:
Wir sind hier in Deutschland!
Dann hätte man sich jedenfalls die Mühe machen können, den Text vor der Veröffentlichung zu übersetzen!!!
Ein Bekannter und ich haben soeben 1,50 h versucht die Funktionen des Apple Car Play zu ergrünen.
Er ist recht gewieft was solcherlei Dinge angeht, aber, auch er hat es nicht hinbekommen.
Ich werde die Tage einen letzten Versuch beim freundlichen HH unternehmen das Ding auf mein Iphone abzustimmen.
Funzt das nicht lasse ich es.
Die vergeblich verbrauchte Zeit ist mir einfach zu schade und ein IT - Studium fange ich deswegen nicht an.
23.06.20, 23:44:48
Ich arbeite nicht fur MRA, ich bin ein Benutzer von MyRouteApp.
24.06.20, 06:01:19
Ok, sorry Jelle,
irgendwie hatte ich den Eindruck einer Produktplatzierung unter dieser Rubrik.
Ja, die App-Entwickler hängen da am Tropf der allmächtigen Torwächter Apple und Google.
Ohne den Zugang zu deren App-Stores ist ihre Software nichts Wert. Ein riesiges Geschäftsmodell gesteuert von wenigen Konzernen zu Lasten der Verbraucher.
Gruß Jörg
02.07.20, 19:23:03
Was für Problem hast ?
02.07.20, 20:36:37
Hallo Ghostrider.1127 und an @
Inzwischen ist das Problem gelöst.
Es lag daran daß sich das HS nicht richtig angelernt hat.
besten Dank an alle die sich beteiligt haben!
05.05.24, 08:07:41
Hi Leute, nun habe ich mir ein Sena Headset in meinen Shoei Helm gefummelt, weil ich unbedingt Calimoto über Carplay auf dem Monitor haben will. Dieses Sena treibt mich aber in den Wahnsinn, es verbindet sich mit allen Geräten, aber leider nicht mit der GW, warum nicht ?……..wer hat einen guten Tipp……..PS ich bin kein EDV Fachmann, wenn dann bitte so erklären, das ein Laie das versteht……..danke euch!
05.05.24, 10:37:18
Welches HS?
iPhone mittels Kabel oder Adapter mit Wing verbunden?
Grundsätzlich das HS nur mit der Wing im Bike Pairing Mode verbinden.
Verbindungen vom HS zum Handy löschen. Die sind sich gegenseitig im Weg.
Handy > Goldwing
HS>Goldwing
05.05.24, 15:43:25
Das Sena SLR2, Iphone über originales Kabel……..wird doch aber erst nach dem Koppeln des HS eingesteckt, oder?
05.05.24, 19:34:45
Ja iPhone nach erfolgreichem koppeln.
Falls du das HS mit der Sena App eingestellt hast musst du die Verbindung SLR2 zu Handy definitiv deaktivieren oder löschen.
War beim 30k auch so.
05.05.24, 21:32:25
Also, HS ist nun erkannt worden, aaaaber das Handy Apple 14 erkennt die GW nicht bei Carplay, alter ich werde irre, was muss man jetzt noch machen?
05.05.24, 22:35:31
CarPlay auf dem iPhone freigeben und es geht nur am Anschluss im TC bei der Tour.
Wie es bei der Bagger ist ????????
10.05.24, 22:46:25
Dia
geändert von: Dia - 10.05.24, 22:49:07
Bei der Bagger ist das Fach dafür vorne in der Tankatrappe wo sonst der Airbag sitzt.
Beim Koppeln gibts nur wenige Sachen zu beachten bei einem "Neustart":
- Kontakt löschen, wie schon beschrieben.
- Alle Geräte Bluetooth aus, die in Nähe sind und sich mit der Godlwing oder dem Headset verbinden
könnten.
- Headset ein, auf Koppelmodus und dann das selbe mit der Goldwing
- Etwas warten, wenns klappt sollte auch oben links im GW-Display ein Kopfhörer mit einer 1 erscheinen
- Danach nur noch das Handy anstöpseln und kurz danach erkennt die Goldwing den Cappaly Modus.
Fertig.
11.05.24, 07:51:28
Dia, genau so sollte es funktionieren, bis zum Symbol HS im Display funktioniert es bei mir. Nur beim einstöpseln des Handys endet alles, das Handy findet die GW einfach nicht, egal welches Kabel ich vorne im Schach anschliesse.
12.05.24, 08:57:55
tibid
geändert von: tibid - 12.05.24, 09:01:24
@blackbike22: Was heisst "findet nicht"? Kommt beim Anschliessen auf dem GW Display eine kurze Fehlermeldung (in etwa: "Carplay kann wegen fehlendem HS nicht gestartet werden")?
Oder kommt gar nix, weder auf dem GW, noch auf iPhone Display?
Was heisst "egal welches Kabel", im Fach vorne sollte nur ein einziger USB Anschluss sein, hast du mehrere?
Bitte folgendes überprüfen:
- HS ist vollständig mit GW gekoppelt: sowohl Musik, als auch Telefon (siehe GW Bluetooth Menu, beide Icons aktiv, beim Verbinden hörst du 2 Beeps, Radio über HS ist hörbar)
- Überprüfe das Adapterkabel zwischen GW und iPhone: es muss ein Datenkabel sein, am besten mit dem original Kabel prüfen (es gibt Kabel, die "nur" zum Laden verwendet werden können und keine Daten unterstützen)
- iPhone vollständig neu starten
- HS zurücksetzen und neu nur einzig mit der GW koppeln
- USB Kontakte reinigen (Kontaktspray)
- wird ein USB Stick an der GW angeschlossen erkannt? (nur zum sicherstellen, dass die Datenverbindung zur GW wirklich funktioniert)
- Befindet sich die GW im iPhone/Carplay Modus? (also nicht im iPod Modus)?
- GW Einstellungen zurücksetzen
13.05.24, 04:57:36
tbid, was heisst im Carplay Modus ?………die GE zeigt tatsächlich nur beim drücken der source Taste ipod neben den Radio Varianten. Wie stelle ich das ggf. um?
13.05.24, 07:00:01
tibid
Die Einstellungen findest du im GW Menü unter Audioeinstellungen, unterhalb von "Uhr" und "Systemeinstellung", oberhalb von "System Zurücksetzen". Dort kannst du entweder "iPod" oder "Apple Carplay" auswählen.
Dies steuert, in welchem Modus das iPhone angesteuert wird.
13.05.24, 09:50:05
Im Video vom Garry wird es doch genau erklärt.
Es funktioniert aber auch wenn die Bluetooth Verbindung nicht ausgeschaltet ist.
